HX EFFECTS FOR YOUR PEDALBOARD
The HX Effects processor was designed to be integrated into traditional amp and pedal setups and may serve as anything from a dedicated multi-effects unit to the command center for your entire rig. Although compact in size, it delivers the same professional-grade sound quality and authentic HX Modeling found in our market-leading Helix processors.
HX AUDIO ENGINE
HX EFFECTS
DYNAMIC RANGE
ANALOG BYPASS
TOUCH FOOTSWITCHES
I/O AND ROUTING
INSTRUMENT AND LINE INPUTS
MIDI INTEGRATION
HEAR HX EFFECTS
HX Effects gives you complete control when editing and crafting effects presets. Click one of the Effects Category icons below to hear examples of those effects types within both simple and complex signal chains.
  • dynamics
  • distortion
  • modulation
  • reverb
  • delay
  • pitchsynth
  • filter
Click play to hear samples.
  • Sample 1
Measurements (in/mm); (lb/kg) 10.8" (274mm) x 7.84" (199mm) x 2.81" (71mm); 4.9 lbs. (2.2 kg)
SIGN UP TO LEARN MORE
Mac is a trademark of Apple Inc., registered in the U.S. and other countries.
