Line 6 DT 25 tube amp with with selectable power tube mode, selectable operating class, and four voicings image
Compact Professional Performance
HX® family products were created for musicians seeking professional-grade performance and sound quality in a compact pedal. They feature the same SHARC® DSP chip and celebrated HX Modeling technology found in our flagship Helix® products, while being exceptionally easy to operate thanks to their color LCDs, simple-but-powerful controls, and capacitive-touch footswitches with color-coded LED status rings. Additional features include a choice of DSP or true bypass, flexible signal routing capabilities, stereo effects loops, footswitch/expression pedal jacks, MIDI functionality, third-party IR support, USB connectivity, and audio interfaces (select models). All this makes HX family processors powerful tools within a variety of applications.
  • AUTHENTIC TONE
  • HX CABS/IMPULSE RESPONSES
  • COMPONENT MODELING
  • BEHAVIORAL MODELING
  • INTERACTION
  • SNAPSHOTS
  • I/O LEVEL SHIFTING
  • ROUTING
  • COMMAND CENTER
  • ANALOG BYPASS
  • HX EDIT
  • POWERCAB
HX Stomp XL
The HX Stomp XL amp and effects processor delivers HX Modeling in a performance-ready pedal with eight capacitive-touch footswitches. The same SHARC DSP chip found in Helix enables it to run up to eight processing blocks simultaneously, and the footswitches let you access and control those blocks in powerful ways.
HX Stomp
The HX Stomp amp and effects processor may be used as a “super stompbox,” a backup or travel rig, an add-on tone expander with other modelers, an audio interface—or a complete guitar or bass rig. It delivers the same sound quality and authentic HX Modeling found in Helix processors.
HX Effects
The HX Effects processor was designed to be integrated into traditional amp and pedal setups and may serve as anything from a dedicated multi-effects unit to the command center for your entire rig. It delivers the same professional-grade sound quality and authentic HX Modeling found in our market-leading Helix processors.
HX Messenger Bag
A custom-fitted carrying bag specially designed for the HX family of instrument processors.
EX-1 Expression Pedal
Compatible with all Helix, HX, POD Go, and FBV family products. It is also compatible with most other Line 6 products.
Line 6 Marketplace
Marketplace is an online one-stop shop for custom presets and impulse responses (IRs) designed specifically to be used with Helix, HX (and POD Go) processors. You’ll find an extensive selection of Line 6-approved products from influential artists and popular sound vendors, all intended to help you increase your sonic possibilities.
ADDITIONAL HELIX PRODUCTS
Helix Native
Helix Native delivers the power of award-winning HX Modeling technology in a plugin. Like the hardware members of the Helix family processors—Helix Floor, Helix Rack, and Helix LT—it features the authentic sounds of vintage and modern amps, cabs, mics, and effects (AAX, AU, VST3 formats; Mac® and PC).
Helix Floor
Helix Floor leverages dual-SHARC processing and HX Modeling to deliver the authentic sound and feel of analog amps and effects, while its interface sets the standard for ease of use. Features include a large color LCD, capacitive-touch footswitches, customizable scribble strips, extensive analog and digital I/O, and an onboard expression pedal.
Helix Rack
Helix Rack leverages dual-SHARC processing and HX Modeling to deliver the authentic sound and feel of analog amps and effects. Its player-friendly interface and extensive analog and digital I/O make it a powerful studio or live processor. The optional Helix Control foot controller adds capacitive-touch footswitches and customizable scribble strips.
Helix LT
The streamlined Helix LT boasts the same dual-SHARC processing and professional-quality HX Modeling found in the flagship Helix Floor and Helix Rack amp and effects processors. Features include a player-friendly interface with a large color LCD, capacitive-touch footswitches, an onboard expression pedal, analog and digital I/O, and a USB interface.
Mission Pedals
Mission Engineering expression pedals are precisely matched to the specifications of Line 6 Helix family products, resulting in a natural response with minimal setup required. Available as a standard expression pedal or with a toe switch.
Helix Family
Helix amp and effects processors set the standard for ease of use when crafting authentic sounding and feeling guitar tones. Helix family products feature an intuitive interface that replaces unwieldy menu diving with straightforward interaction. Helix products are also remarkably versatile and may be used in a variety of applications.
SHARC is a registered trademark of Analog Devices, Inc.
Mac is a trademark of Apple Inc., registered in the U.​S.​ and other countries and regions.
