Jul 10, 2012 4:47 AM
new jtv 69 guitar on off with batteries problem. HELP
Like (0)
I just bought a Jtv 69 new listed on ebay. it was new . Awesome guitar! i was playing around with the magnetic pick ups and was really happy i made the purchase.
I waited for the batteries that were supplyed to charge fully to test out the variax functions . And then i put the battery in . it shows leds fully charged in the back of the guitar .
I press the guitar model button to engage and then it does nothing . i press for 2 seconds i press a quick 1 sec , 10 sec nothing . it just wont turn on using batteries .
So i was bummed out. then since i had pod HD500 i hook it up using the digital cable, it turns on blue lit knob and works fine with this cable. Good sound works with bench software!
I was dissappointed with the craftmanship of the new guitar on the electronic side. as this important feature should have been tested out at the factory. THe reason i bought the guitar was to use variax modeling technology and it
does not work to turn on.
. the seller of this guitar is offering a $100 discount if i
decide to keep this guitar. if so do you think i should return it and get a new one or get this one fixed by line 6 this guitar is new and has blank warrnty papers, but i bought it on ebay
please some advise from the pros would be nice TIA . thanks for reading this post.
It sounds like you either have a faulty battery, or there is an internal problem with the battery circuitry.
If you can persuade the seller to send you a replacement battry on a trial basis while holding your return option open, I would start there. Then if the new battery doesn't solve things I would return it for a replacement.
Personally, I would not take the $100 discount to keep the guitar as it is. While you could probably get it fixed through Line 6 warranty, it could be a lengthy process leaving you without the guitar at all for a long time.
By the way, the fact that the warranty papers are blank does not mean that the guitar was not pre-owned, registered, and for some reason returned to the eBay seller - who is now reselling it as new. I know!! Who could imagine??
If that has happened, your warranty period has already at least partially expired.
Just phone l6 to see if serial is registered and at the same time ask about your power issue.
Thanks for the tips. I 'l try calling them and see. I 'll post an update to what happend.
